{ FS } Race Roots Engine / Motor Mounts
SOLD - Race Roots Engine / Motor Mounts
Price: $150
Price includes shipping (within continental US)
These are the steel version, and are a direct replacement for your worn out factory one. Used with some paint chips on the edges. Easy to touch up with some spray paint if you choose to.
From Common Issues
- Motor Mounts:
Our motor mounts collapse/degrade over time. This causes the car to shake more, especially at idle. This isn't the actual engine attachment points, but rather just the vibration dampeners. However it is not inherently a problem that you need to rush out and fix. Adding more vibration to the car isn't inherently bad, but can lead to other problems with rattles and joints wearing down. Most people choose to live with it. If you are getting a lot of shaking and vibration at idle, but the tachometer needle is stable, then motor mounts should be the first thing looked at for a solution.
