RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } 2004 rx8
Old 07-22-2024, 03:43 PM
cliffkemp's Avatar
2004 rx8
I have a 2004 rx8 up for sale now. It is partly gutted as I was going to autocross it. Things changed. I am getting rid of cars I don't want. I will take no less than 1200 for it.
The good:
Has only driver's seat.
Radio works and stock, but only when interior is warm inside...I don't know why but sound doesn't work if it gets cool inside the car.
A/C works last time I tried it.
Nothing leaks.
The bad:
low compression, but starts and runs but will not restart hot.
driver's side window only goes down about quarter inch. Passenger side is fine.
chassis has 193,xxx miles.
fuel pump assembly nipple is slightly cracked. Will drip gas, slightly, when pressurized so, I rarely drive it due to smell of gas. New assembly is less than 150 dollars.
Car is dark green with very minor rust. I have put 13,xxx miles on it despite the bad compression so, it could go indefinitely or seconds before motor may throw a seal. I premix 1 quarter of 2 stroke oil to a full tank. Trans is decent but 2nd is rough in higher rpm changes if you try to race it.
if interested, text me, don't call. 404-202-3881. I will answer any questions that I can. It will come with stock wheels. Good tread depth on the tires, too. It will not come with a battery unless you want to pay more for the car. I have a relatively new antigravity battery in it. If you want it, too, will be extra. Has upgraded rotors and hawk hp+ pads and stops very well. Not sure how much pad is left though. Text if interested.
thanks
Dani Harris
10-12-2018 11:06 AM
rx-fish04
01-15-2017 02:59 PM
rx-fish04
12-29-2016 10:14 AM
kleach18
Gulf For Sale/Wanted
02-08-2015 03:17 PM
twistedwankel
12-13-2012 03:01 PM
Quick Reply: { FS } 2004 rx8
