Lambo Doors
Old 01-07-2006, 06:17 PM
Lamiellm's Avatar
Lambo Doors
I think the first thing i wanna do to my caris get the lambo doors! Who and what brand do you recommend? Are they hard to install yourself? I own a mechanics garage so i have all tools at my fingertips!
Old 01-07-2006, 06:47 PM
Student Driver
Isn't this your car?
Old 01-07-2006, 06:49 PM
Lamiellm's Avatar
I got a replacement!!! No they arent for that one!
Old 01-07-2006, 08:25 PM
Student Driver
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/my-gt-factory-90degrees-lambo-doors-mechanism-installed-69593/
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/vertical-doors-pics-74296/
https://www.rx8club.com/showpost.php...5&postcount=52
This might help too....
Old 01-07-2006, 08:27 PM
don't do that to your car!!!! Please no!
Old 01-07-2006, 09:15 PM
MazdaManiac's Avatar
Installing it yourself (unless you've done extensive bodywork before - including fabrication and welding) is not suggested.
GT Factory makes the most stable system. That is what I have.
Expect to pay about $1100 for the system and another $1k for the install.
Old 01-07-2006, 09:29 PM
cry me a river...
EZZY's Avatar
it will be easy to install it yourself if it is a pre-made unit (with basic tools and have a brain), not one of those universal fit ones where you need to modify to fit.
Old 01-07-2006, 09:51 PM
There is no "bolt-on" kit for the RX-8. It isn't possible because the fender clearance is too low.
It requires cutting the sub frame to recess the hinge box so that the swingarm doesn't contact the outer line of the fender.
Old 01-08-2006, 10:03 AM
kcmo's Avatar
Mine is the second link. I haven't had any problems with the doors, I have had to adjust one door once, which was kind of a pain. In the pictures you can see that the doors don't go a full 90 degrees. I would recomend getting a kit that does go the full 90 for entry and exit. But you will get used to whatever.
Old 01-13-2006, 12:46 PM
RX-8fan01's Avatar
I just put the "bolt" on kit on my car .. and it was real shitty .... nothing fit how it was suppose to ... and its kinda anoyying you ahve to be way carefull closing the doors
Shane
i will post pics soon
Old 01-13-2006, 01:22 PM
Fire-Spewing Maniac
Bindon's Avatar
I would get this done if they had actuators fitted in the joint, so I could use my key fob to open my doors automatically. That woudl be so amazing. Not only would it be functional, but mucho bling :-D
Old 01-14-2006, 12:07 AM
Shane
I warned you all about that.
AutiLoc makes an actuator kit that could be used in conjunction with the GT-Factory system.
Old 01-15-2006, 12:39 AM
Fire-Spewing Maniac
Bindon's Avatar
was the shitty bolt on kit GT factory???
Is the autoLoc kit, a kit for just keyless entry? or would it allow me to have to door lift up when the button is pressed?
Old 01-15-2006, 01:07 AM
No. GT Factory is the good system. It is definitely NOT bolt-on, though.
The AutoLoc stuff is linear actuators and poppers. It will open and lift the door and pull it back down again.
Old 01-15-2006, 05:52 AM
BlackRevo81's Avatar
i think the best you can do is to buy a bolt-on-kit from germany.
here is the link
www.lsd-doors.de
you don´t need to weld, just bolt-on and be happy
sorry for my english.
here is the adress for the USA
KW automotive North America Inc.
Brandt 1075 North Avenue
USA-93657 Sanger,
CA 1 559-875-0222
1 559-876-2259
Old 01-15-2006, 11:28 AM
RX-8fan01's Avatar
It was a company with GT factory ..... but i cant remeber what it was called sorry ....
Old 01-15-2006, 11:47 AM
here is the link
www.lsd-doors.de
Yeah, I saw one of their kits recently in L.A.. Nice concept, but it leaves the door really floppy and flimsy feeling. The closing alignment kept changing making it hard to tell where the door was actually going to close.
Old 01-15-2006, 12:38 PM
Even My Dog Searches
Mugatu's Avatar
keep lambo doors on lamborghinis.
Old 01-15-2006, 12:54 PM
The newest Lamboghini has regular horizontal doors.
Old 01-15-2006, 02:31 PM
Mugatu's Avatar
see, even lamborghini knows that those types of doors are pains in the ***.
Old 01-15-2006, 02:46 PM
Vertical doors are no more difficult than horizontal doors, unless you are fat or otherwise immobile.
I guess it is an American thing...
Old 01-15-2006, 06:07 PM
Fire-Spewing Maniac
Bindon's Avatar
I Searched AutoLoc on google but didnt find much. Do you have a vendor for a kit like this?
I just to see pricing etc.
And when you say not bolt on, how many hours of work did it take you to install them?
Old 01-15-2006, 06:16 PM
It took me about 12 to 14 hours, but I have a lot of experience with this sort of thing. A pro shop with two or thee techs would probably be able to do it in about 8 hours. The average enthusiast would only be able to ruin their car in that span at best.
The AutoLoc stuff isn't a kit. You would buy two poppers, two actuator, the controler and the harness then install it all yourself. The actuators would replace one of the two support struts per door that are included in the GT-Factory system.
Old 01-16-2006, 04:24 PM
BlueEyes's Avatar
You don't know much about the history of lamborghini do you? Or why they use(d) scissor doors?
Don't try to justify ricerness with nonsense.
Old 01-16-2006, 04:37 PM
Uh, OK.
I owned an LP 5000S for a while in the middle of the 90's. Got tired of it overheating every time I came to a stop.
I don't need to justify anything. Are you trying to justify anything?
Quick Reply: Lambo Doors
